AndrewE430
- Apr 30, 2006
I've recently bought a W210 Mercedes E430 Estate on 28th April with 86000 miles on the clock.
Four days ago I tried to start the car in the morning and I got a clunk sound - it wouldn't start - the interior light worked, radio worked and dashboard lights were on initially.
My garage didn't think it was the starter motor suggesting these were reliable with Mercedes and pointed to the battery.
I started the car with a start & charge clipped-on to the battery in the evening and thought fine that will be it - engine left running for a while with a few revs.
Next day, didn't start - same problem clunk - two start and chargers attached - didn't start - clunk.
Replaced battery the following day with new Bosch 100amp unit - must have had original battery fitted previously as stamped 03/99 on negative side of Mercedes battery.
Warning lights come up "BAS" then ESP/BAS then Antii Lock Brakes/ABS warning triangle.
Manual states if battery disconnected turn wheel lock to lock (which I did) and lights will go out - which they did.
Manual also states loss of power from was it BAS or ESP.
Drove car on Friday morning at first I thought it had choked itself, but it was quickly apparent that the power had been lost.
At arrival at work (17 miles) switched-off then the car would start - clunk.
3 hours later started - took car to garage - struggled to go uphill at about 2 to 5 mph - though I would stall at one stage - stopped and started off again.
Initial examination at garage centred around something electrical - nearest plugs and air filter examined in my presence - possible question mark whether car has been serviced or not.
Any ideas anyone - including garage road test - car has only done 505 miles under my ownership.
Many thanks,
Andrew
Many thanks,
Andrew
