sviveknaidu
- Jun 10, 2009
can some one advise me
I have a 1997 E 250 D with a rather peculiar problem. The engine RPM will increase steadily as i depress the accelerator slowly up to 2000 rpm and then with the accelerator held steady at that point the RPM rises on its own till the Maximum.
My mechanic thought it was a furl pump problem and had it taken out and checked and when he fitted it back, the engine has a very loud knock at idle and upto 1500 rpm as i depress the accelerator. after 1500 rpm the engine smoothens out but does not have the same power as earlier.
also earlier the idle rpm was about 600 and now it is closer to 900 rpm.
can anyone please advise what i should do to soften the engine noise and get back the power of the engine and what could be a possible cause for the engine revving to maximum on its own after 2000 rpm.
also the mechanic had removed the injectors and replaced them after checking them., Are the injectors cylinder specific as they were randomly fitted back after cleaning.
