Micky P
- Jan 10, 2021
- C class 2012 1.6
- Thread Starter
- Thread starter
- #21
This was the video the garage sent me with a little explanation - you’ll be able to hear the noise im referring to - as it’s in the garage it doesn’t seem as loud but when outside it’s a lot more noticeable
https://video.bookmygarage.com/Yls9y
The only time I've heard mine ticking the way you describe, is when the DPF is going thru a regen and I've parked up and turned engine off.
The regen causes a huge rise in exhaust temperature and the ticking is it cooling down
Pinking is a ticking sound . When a hot exhaust begins to cool down. If it was the central locking pump , you could replicate that sound without driving or even starting the car.
Would car breakers be an option as well ??
I have had it on occasions on my 212 E350CDI, normally after a long run. I just assumed it was something like the exhaust cooling down, its been there for nearly 9 years. I have just lived with it.
It will be the exhaust cooling down in the cold weather.......... get it checked but I very much doubt they will find anything wrong with the car.
Fuel pump often mounted rear d/s ??
