Low level warning light for screenwash fluid - W124
ArtistsRifles
Am I correct in thinking that the warning light for the screen/headlamp wash fluid should go out once the reservoir is refilled??
Only I did ours at the weekend and it's still on - this makes me think, if the answer to the above is yes, that maybe a sensor float has stuck and requires some "percussive maintenance".........
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Yes it should and as you say "percussive maintenance" could be the way forward.
Mike
A
ArtistsRifles
Sorted - in a highly embarrasing way! :Oops: :Oops:
Checked the reservoir - and it was empty again so I filled it up and listened - sure enough, sound of running water. After a bit of digging it transpired that the hose to the headlamp washers had come off :Oops:
Put it back on and pushed it home firmly - now all is well......
Teach me to check first before making assumptions :Oops: :Oops:
996jimbo
C43 estate
Hope you hit it anyway - just in case!
Mikesmerc
Co.Cork IRL
Such things seem to happen to me more often than I would like:(
Mike
clive williams
A human at last!
I'd still take the advice about some 'percussive persuasion' but apply it to the whole car just in case!!!
