Low revs Misfire 300CE Coupe
Status
Not open for further replies.
crazyquiff
I have an '89 300CE Coupe 3sp Auto.
At low revs and worse when engine is warm I get a bad mis fire - the engine has no power at all. The only way to get going is to use very light throttle to get the speed and revs up a little or use low range - once over about 1500rpm it performs fine with no hint of the problem.
Also the car is a little rluctant to start - have to use lots of pedal
I'm suspecting high tension plug leads - am I correct?
Cheers
Rich
Francois
The same happended with my and after replacing the HT leads and dizzy cap it worked fine.
C
crazyquiff
Problem sorted - damp in the dizzy cap - so i dried it out and cleaned up all the posts and rotor arm.
No cost solution!
Francois
Always nice to see people find a cure for the loved ones. :D
Status
