I've used lpg on a M102 engine for three years without any problems whatsoever. Before you decide either way, consult an installer who is an approved member of the LPGA. Also, only consider a closed loop system which uses an exhaust oxygen sensor - early installations did not include this item and were prone to the symptoms mentioned in Andy's post. It's worth paying a bit extra for a quality setup and the provision of an approved installation certificate for your insurance company. Hope this helps, good luck.
