- Mar 14, 2005
- Age
- 89
- Location
- Daventry
- 2002 SL500, 216 CL500, all fully loaded
Care should be taken when replacing the lower ball joint in the front and rear suspension, otherwise it can become expensive.
Replacing the ball is uaually straightforward, the problem starts in the second stage in the pre glued ring to install the joint.
As the ring is turned the heat generated melts the glue and allowes it to flow but as the force needed to get the torque up to 350Nm is hard work, its normall to take a rest, but if you do the thing sets, and you have to start all over again, and chissel the old one off.
As the joint cost £90 each plus VAT it could turn a simple job into an expensive one. The locking rings are not sold on their own so you have to buy a complete new ball unit.
So remember to torque it up to the 350Nm in one go, the trade use a special tool to torque it , and then fit the ring.
Malcolm
Malcolm
