M113 E500 runs cool on a run and hot in traffic
yinujim
Essex
92' 500SL, 04' E500 Estate
Hi I have M113 E500 that seems to get up to 93c in heavy traffic but once you get on the motorway its reads a low down to 67c. I have replaced the original thermostat with a 87c Vemo thermostat and nothing has changed. There is no coolant loss, the heaters blow hot and the electric fans are working.
Does anyone know what could cause such wide fluctuations?
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
You say the fans are working. Have you checked the temp they cut in at? Thermo switch may be faulty.
Y
yinujim
Essex
They cut in after 93C. In the summer in traffic it creeps up towards a high of 95, 96 and drops down to a low of 88-90 on the motorway. In the winter its a high of 89C in traffic and a low of 67C on the motoway
oigle
The only one that is out of synch is the 67° on the motorway. The thermo should prevent that unless you are travelling in VERY cold temps. Maybe consider some blanking off of part of the radiator in winter.
brandwooddixon
Wolverhampton
S63 Coupe 2014
With the temperature dropping on the motorway I would have said thermostat is the issue even in the winter I wouldn't expect it to run that cold.
I know that you've replaced it but it could be a defective thermostat. It might also be a defective temperature sender or connector.
I'd be tempted to test the thermostat using a Pyrex jug, a jam thermometer and some hot water.
Y
yinujim
Essex
Yes I might have to try that along with a coolant flush as it looks due for a change. There is also some slight play in the water pump pulley with you wriggle it up and down.
