Alex Crow
- Jul 9, 2009
- Location
- Super Suffolk
- W169, W124, w202, W203, KTM 250 EXC, VW T25 camper and a Polo in a pear tree
OK, so now we need to trace why no 12v at pin 1...
So, pin 1 gets power through fuse F24/8 circuit 15 auxiliary fuse, which I believe is mounted on its own near the engine ECU - you may have seen it.
Hi again. With your and forum help I continue sorting thing out. Now that my MAF and ECU powered I had a chance to test MAF. It sends all the right signals to ECU. 5v from pin 4 and variable voltage from pin 5. About 1.9v at idling and rasing to 3.1v at 2.500 rpm. Yet, if I disconnect MAF motor revs the same...It looks like ECU doesn't care or could it be "nobody home"
... just to stick 5 Kohm resistor pins into a motor connector ? Thanks
Oh, I made sure of this. Thanks.Yes, that is the idea and works quite well, although you might want to make sure it is well protected.
If I may ask some more advice...
My car is 2001 ML270 CDI and probably doesn't require sophistication of SDS. Maybe you can recommend some basic tool that can read DTC and communicate with ECU .
This car came to me without thermostat . It is always very warm here in Panama so I am not in a harry to install one, also recirculating motor for coolant is shut. Local mechanics advised me to delete it and reconnect hoses, since heating is never needed here...I did it. Is it a good idea to shunt a connector for the motor, so it will not send a unwanted signals to ECU? And if you agree could you recommend the resistor size .
