Maf sensor clean
ssheikh93
London
W213 E220d
Had a fault code showing maf sensor issue. No engine light but getting no boost.
Read that you can try and clean the maf sensor.
Might be stupid question but I'm assuming there's only one? And can I use isopropyl alcohol to clean ?
Lastly how to locate it?
W213 e220d
ssheikh93
London
W213 E220d
  • #2
Too add, on first drive of the day, the car goes back to normal them after a while of driving there is no boost.
ssheikh93
London
W213 E220d
star
Reading
Smart + others :)
Very rarely a maf fault on this engine, never changed one yet. Normally something else. What diagnostic are you using?
mioba
Nottingham and Köln
If you want to clean use carb cleaner or electrical contact cleaner. MAF located directly after the filter. Follow the air canal it will have a wire attached.
If it is the MAF, buy genuine mercedes.
Good luck.
ssheikh93
London
W213 E220d
Local indy plugged in using xentry
ssheikh93
London
W213 E220d
Good luck.
Have you located it..?
Is this it? Seems to be 2 clips and a sensor attached? Any other screws or clips? 20210809_103408.jpg
ssheikh93
London
W213 E220d
I've opened it and there seems to be oil?
Is this normal?
Taffy7hfa
Oxford
mattkh
England
A160 W168 1999 1.6
Is this normal?
Well done,
Clean the oil.
Use a spray can (Wynns air flow intake cleaner) cleaner tube to go through the gauze and take the film of oil off the sensor.
Do not touch the filaments of the sensor. Allow to evaporate.
By the way, can you see the plug to the sensor, how many wires and what colour..?
ssheikh93
London
W213 E220d
Well done,
Clean the oil.
Woops I uses isopropyl alcohol and also I used a cotton bud to clean the little sensor bit inside.
I'll haven't actually driven it yet but I may have to buy another one
mioba
Nottingham and Köln
I did mention what to use to clean.
Why did your indu not change it.
As mentioned get genuine.
For future reference do not touch the hot wire/film as it is incredibly easy to damage. Cleaning rarely works and can hasten the sensor demise. The reason for this is the deposits (often only oxidation) burn into the wire and slowly it away. Cleaning it makes the wire thinner which then changes its electrical characteristics and makes it more prone to failure.
ssheikh93
London
W213 E220d
rayhennig
1991 300CE-24 Sportline
This is what we did on my son's VW Gti and it worked for a while. An expensive replacement was the definitive solution.
R
