MAF sensor
mark sutton
Little Chalfont
Hi all
I bought a new pierburg maf sensor back in may I fitted it ran my ML for about 1000 miles then got the limp mode back again very intermittently but has become more frequent, so went back to eurocar parts this morning and they did a straight swap I drove 8 mile with the new sensor fitted then got limp mode again, surely it can't be the maf sensor so soon.
Can anyone help me with this as I have had this problem since a bought my ML back in April.
many thanks
mark
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Mark
Was there any oil residue on the MAF? is there any oil on the rubber pipes on the left side of the engine around the tirbo inlet.
jib
M
mark sutton
Little Chalfont
No there is no oil residue on the MAF sensor and no oil on pipes around turbo.
the first sensor I took off was very clean, I changed the air filter when I fitted the new sensor.
I now I shouldn't but to prove a point should I run the car without the air filter to see if it's lack of air flow that's the problem ?
many thanks
Mark
jibcl500
Cambridgeshire
CL500,ML55,SLK280
You really need some giags run on the car, on tick over without moving wouldnt hurt but I cant see the air flow being a problem.
What about the brake pedal switch have you thought about replacing that £9 or so from MB.
jib
M
mark sutton
Little Chalfont
How would replacing the brake light switch cure my problem please tell me more.
many thanks
mark
The 02 sensor can put the car into the limp home mode, but normally with the light on(engine)
M
mark sutton
Little Chalfont
No lights on the dash at all.
when I got home I turned the engin off waited about 20 seconds restarted it and it reved fine, same thing with the old sensor, I have read on here that it resets the sensor when you switch off so that's why i think it's the sensor but now I am having second thoughts.
many thanks
mark
This could be the conductor plate in the gearbox, not expensive,, get an indie to read the codes
M
mark sutton
Little Chalfont
Thanks for the info your right I will have to get it on a diagnostic machine to hopefully sort this out once and for all.
many thanks
mark
P.S I will post the results when I get them.
D
dark1429
if you put it on the fault code machine it will tell you what is wrong, common fault is a sensor but there are loads the fault code will tell you which one it is
