Manifold Actuator
isohail72
Manchester
Mercedes S320 CDI 2006
Hi Guys, Does anyone know where the manifold actuator located.
Getting this code. P2015,Intake manifold air control actuator position sensor/switch , bank 1 - range/performance problem , intermittent fault
isohail72
isohail72
Manchester
  • #2
Any help pls?
Any help pls?
Do you mean the inlet port shutoff motor that operates the swirl flaps in the inlet manifold ? Also , your user pic is not a 2003 E class ? Which engine are you referring to ?
isohail72
isohail72
Manchester
Its mercedes s320 cdi 2006.
If that is the om642 engine the ilps motor is behind the fuel filter and under the black batwing which goes to the front of the turbo . The orange turbo seal tends to leak sludgy oil onto it (if this is your fault ????)
isohail72
isohail72
Manchester
Yes, i think you got it correct, just been to Inde John Delany Motors, he told exactly the same quoted £500 with star diagnostic labour and parts, is it a good price?
I leave that one for the experts buddy :D
isohail72
isohail72
Manchester
Still, he said 3 hours of labour?
isohail72
isohail72
Manchester
Where is honesty gone these days!!!
www.W140.co.uk&www.r129.co
