I have a problem in my 1995 w202 C180 Manual Transmission model. The problem is when I engage the 1st or reverse gear, mostly on reverce gear, and trying to start smoothly,( letting go of the clutch slowly, and obviously giving the car enough gas so it's not stalling or anything), like as unpark carefully with slight accelerator (I'm about 50% off the clutch), the car starts jerking with clanks and only if I release completely the pedal quikly everything going normal.
All the other gears shift fine, No jerk even I start with 2nd gear.
Clutch kit, flyweel and trasmission fluid has been replaced three months ago. Also we have found out that the previous one ( the old one) was in a good condition and the idiot problem remain exact the same.
Gearbox rear mount and propeller shaft couplings are ok.
No any fluid leak inside or outside transmission and the funny mystery is that if i don't drive the car for a day the problem dissapear and everything is smooth and perfect, but then after I drive for a bit (~30 min), especially in traffic it will be present again. The problem went bad to worst during the driving day by day.
Any comments of this problem?
Thanks in advanced
Mike
Thanks in advanced
Mike
