Merc 1999 E240 W210 Saloon
Bongo bear
HI looking for advice on my auto gearbox, had a prob couple weeks back loosing the drive to the box when slowing down or idling, switch off engine restart and it works fine maybe half a mile then same again, changed atf and filter and went well for 2 weeks then the same problem occurs, now I've changed the torque converter oil, all to the correct level. AND now it won't shift from what is 2nd gear !! Throttle up and down no change. Any ideas it all sounds OK a little jolt when you pull the stick back into the drive position but just won't change. ???? Thanks.
Needs to go on diags to be sure but sounds like the conductor plate is on its way out..
B
Bongo bear
O right thanks mate, I'll get it checked out, it will show on the diags presumably thanks
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
The car needs taking to a Mercedes specialist with Star diagnostics. The transmission related fault codes will show the problem.
As above, I'd suspect the conductor plate.
malcolm E53 AMG
Does sound very much like the speed sensor in the conductor plate is failing sticking in 2nd gear is a big clue there are specific fault codes for this if you search the web
