MERC 320sl GEARBOX
ecaf
i am a new user to this forum, ello to everyone.
i have a mercedes sl320 s reg 1999, which requires a new gearbox, i have located a gearbox, however it is off a ml320, which is a four wheel drive.
would i be able to fit this gearbox on to my sl320
i would very much appreciate any feedback on this
many thanx:confused::confused:
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
im not familiar with either box but i would imagine that the ratios will be different in the ml box and the entire box will meed modified as a 4 wheel drive gearbox has a transfer box/center diff mounted at the back of it fo the drive to the front axle. any 4 wheel drive boxes ive worked with, the transfer box was not a bolt on unit without stripping the box. even if this was done, theres no guarantee it would fit. i think id carry on looking for a gearbox out of another sl, or maybe something like a c320 or e320 gearbox will fit. i think they would be more likely to fit, but its not my strong point im afraid. im sure someone will be along shortly with the answer you need!
There must be 2 post running on this as I have answered one
turbopete
Spennymoor
i havent seen the other 1 Malcolm!
turbopete
Spennymoor
well it says its sticking, but sticking where? in gear? in 1 gear? i see what you mean. it may be a relatively cheap fix! are the gearboxes unique or would a box from another model fit, perhaps with a changed bellhousing? (assuming theyre removable)
