Mercedes 500sec direction indicator problem
andykayll
New Registration
Hi All,
Hoping someone maybe able to help here/or have had the same problem.
I have a 1987 500sec, so far everything seems to have been working ok, but recently, the indicators have been causing problems.
With the ignition off - the hazard lights work fine and everything sounds normal, however, switch the ignition on and the offside front, rear and repeater are on static (the indicator stalk is in the middle/off position)
Sometimes the nearside indicator is on static too, but when it isnt, by moving the indicator stalk to operate the near side, they flash (but the offside are still on static)
Im guessing that because the hazards are fine the flasher unit will be ok. I have alos removed fuses etc, and still the offside indicator remains on static.
Made me start to wonder if there are relays somewhere else that control indicators,
Any help at all would be greatly appreciated!
Andy
