Mercedes a class 2007- door handle issues
welly84
Hi, I've recently purchased a 2007 a class. The door handles from the outside won't open the doors. I've had a look and it looks like grub screws have been removed?
The handles can be pulled without engaging. Obviously this will result in an MOT failure. Has anyone had this issue, tips to fix without spending a fortune would be good!
Thanks.
DREAMER NO2
W124 2.6E M103 1989
Without knowing just what model you have ,then i dont think anyone will be able to help you,,i recon there must be over so many A class models in the mercedes range . ---- You need to put all the information on your car in your profile .Thats the part on the left under your name
London
Mercedes 2008 CLC 180k sports coupe
It might just be loose screws inside the handle. Check a hardware store for replacements; they're usually cheap. You can find some DIY guides online, too.
W
welly84
Hi, thanks....I managed to get the door panel off etc...links like the spring has been removed from the mechanism weirdly?! Anyway a quick ebay visit and parts sorted, hopefully it's not too difficult to fit!
