mercedes battery
giuseppe
Bournemouth
E220Cdi avantgaurde 2001
just bought a 100ah battery on E bay, I assumed it is okay for a e220 diesel, can anyone tell me if my assumptions are correct. cheers
There is more to it than the size was it a good make
G
giuseppe
Bournemouth
Hi malcolm, it is a mercedes 100ah battery, just picked it up, weighs a ton, leaving it on charge overnight, hopefuly it will cure my "alternater/battery warning",
Alex Crow
Super Suffolk
which model e220 is it? w211, w210?
it wll be fine for the 210, but the 211 has a gel plate battery (it has vrla marked on top) and it is only about 75ah.
G
giuseppe
Bournemouth
it is a W210 E220 cdi avanguarde 2001, which is a bit of luck
Miffy
Bromley, London
CLK 320 CAB Elegance C208
that reminds me that I still need to go buy a new battery 110amp to replace this 88amp, is there a market for batteries under 1 year old?
turbopete
Spennymoor
why are the gel batteries lower rated then? and does a 211 need less power to crank etc than a 210?
In the 230 that I have a separate starter battery up front, and the gel battery (AGLM) is in the rear
turbopete
Spennymoor
so your car cranks from the battery up front, but the gel battery powers the car? does that mean theres some kind of equivalent to a split charge relay (as used for caravans etc) somewhere in the set up?
Miffy
Bromley, London
Gel cells can release 30% of their rated power for cranking, lead acid can only release 25%, so for any given draw on the cell, the Gell battery can be quite a bit less in its overall rated output
turbopete
Spennymoor
so assuming they were equal on price (gel are probably expensive though) what would be better for my car when the battery gives up the ghost on me?
Miffy
Bromley, London
I dont think you can just swap a lead acid out and put a gel in place, they have a very different charging requirement and may be damaged by your existing setup
turbopete
Spennymoor
never knew that either! today is certainly a learning curve!
Miffy is spot on with that info
