Mercedes Benz 240E 1998 issues
cemos1963
Melbourne, Australia
mercedes benz 240E 1998 v6
i have this car for 5years and never have any major issues but three weeks ago,. i was driving and a few lights came up on the dashboard and funny noise from the motor/ gear box (i don't know)that the power slow down and acceleration is gone. i stopped and i waited for the motor cool down. i drove another 2k but it happen again.
i have towed the car to the mechanic. the mechanic did all the Eletronic test but couldn't find anything.
i just want to know if anyone have this problem
rich.g.williams
Cardiff, South Wales
C200 Kompressor Coupe 2003
confirm type of transmission i.e. manual or automatic (5G-Tronic), if automatic have a look at threads related to 722.6 transmission, but your problem sounds like engine, confirm if your transmission is still changing gears or stuck in one gear
lights coming up on dashboard suggest engine problem, what lights come up please? is it only engine management light if others what others? more info please,
C
cemos1963
C
cemos1963
Hi Rich
thanks for your respond, the transmission is automatic.
during that week when the different signs came up, they were BAS ASR, ABS, LIM, the cruise control wasn't working. the only lights were working the high beam, brake and the fog lights
the auto transmission still working
rich.g.williams
If Abs bas esp comes up I think cruise control is turned off for safety, so your mechanic did not find any fault codes yes? This event was temporary and went away yes
Others will know more about this but if the fault came and went away I would be thinking battery problem electrical power problem bad electrical earth connection etc. Something that happened intermittently. Maybe it is simply an abs bas esp problem that is intermittent but should leave behind a fault code to explain the event whereas a battery electrical power problem might not record a fault code
Maybe someone else can comment otherwise find a different mechanic with more experience of this car
C
cemos1963
the mechanic went thought the electrical test but couldn't find anything. the battery is only 3 years old. i left the car with them for 2 weeks so they can drive it but everything was normal. do you suggest anything else
ajlsl600
france
If no other information start by clean, check all your earth points
