- Feb 8, 2013
- Location
- Essex
- Website
- www.gadtuning.co.uk
- Mercedes AMG GTS - GLS350d
Hello members
We will in the coming weeks be installed the Wagner Competition Radiator upgrade kit to our own C63s AMG Edition 1.
Its something we will in the future offer as an upgrade to the OEM charger cooler rad pack as these as many AMGs especially turbo charged models CAN suffer from heat soak especially when running high states of tune!
Below are details of what it will consist of....
Competition Radiator Kit for the Mercedes Benz C63 (S) AMG
Mercedes Benz W205 C63 AMG 350KW/476PS (since 2015)
Mercedes Benz W205 C63S AMG 375KW/510PS (since 2015)
The 4.0L V8 biturbo engine of the specified C63 (S) models from AMG is equipped with an indirect charge-air cooling circuit. So the cooling of the charged air is not realized by the ambient air as cooling medium (as usual), but made with its own cooling water circuit. A reduction of the temperature of the cooling water is directly equated with an improved cooling performance of the charged air. This is exactly where the advantages of the WAGNERTUNING upgrade water cooler comes into play.
The new developed competition racing core of the WAGNERTUNING high performance water coolers increase the radiator volume of the OEM water coolers by a total of 80 %. The calculated ratio between the inner and outer cooling surface generates a maximum heat transfer and allows at the same time enough air flow for the surrounding components (for example the engine water cooler) for its own heat exchange. The water coolers are equipped with a heat-conductive anti corrosion coating to ensure a lasting cooling effect. The plug & play installation of the system is simple and easy to perform (installation instructions included).
Dimensions OEM front mounted radiator:
640 mm x 430 mm x 27 mm
V = 7,43 Liter
A = 2752 cm²
Dimensions WT front mounted radiator:
645 mm x 395 mm x 52 mm
V = 13,25 Liter
A = 2548 cm²
Dimensions OEM side mounted radiator:
240 mm x 250 mm x 27 mm
V = 1,62 Liter
A = 600 cm²
Dimensions WT side mounted radiator:
240 mm x 240 mm x 52 mm
V = 3,00 Liter
A = 576 cm²
For any enquires please feel free to pop an email over to info@gadtuning.co.uk or call direct on 05603 67 21 09
https://www.gadtuning.co.uk/
https://www.gadtuning.co.uk/rolling-road-essex/
Many thanks
V = 7,43 Liter
A = 2752 cm²
V = 13,25 Liter
A = 2548 cm²
V = 1,62 Liter
A = 600 cm²
V = 3,00 Liter
A = 576 cm²
Many thanks
