Mercedes Benz Oil Specs listed in full
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
MB 226.9
Multigrade engine oils for gas engines (CNG) based on Series 300/400 engines.
MB 227.0
Monograde engine oils for non-turbocharged diesel engines (Series 600).
MB 227.1
Multigrade engine oils for non-turbocharged diesel engines (Series 600).
MB 228.0
Monograde engine oils for turbocharged diesel engines. Oil change intervals up to
30,000 km.
MB 228.1
Multigrade engine oils for turbocharged diesel engines. Oil change intervals up to
30,000 km.
MB 228.2
Monograde SHPD engine oils for highly turbocharged diesel engines.
MB 228.3
SHPD engine oils for highly turbocharged diesel engines. Extended oil change intervals
up to 45,000 km.
MB 228.5
UHPD engine oils for highly turbocharged diesel engines. Extended oil change intervals
in light-duty engines up to 45,000 km. Up to 160,000 km possible in heavy-duty diesel engines (with service interval displays).
MB 228.51
UHPD engine oils for trucks fitted with exhaust gas after treatment. Low ash content required.
MB 229.1
Engine oil for car gasoline and diesel engines. More stringent than ACEA A2/A3 and B2/B3.
MB 229.3
Engine oils for cars with extended oil change intervals (30,000 km).
MB 229.31
Engine oils for cars with exhaust gas after treatment. Low ash content required.
MB 229.5
Fuel Economy engine oil for even longer oil change intervals (vehicles from 2002 on) with service indicators. Special, stricter requirements than ACEA A3/B3. For use in all car gasoline and diesel engines. This oil also complies with 229.1 and 229.3.
MB 229.51
Very high performance oil for engines with diesel particle filters and extended oil change intervals. Better fuel economy than MB 229.5.
You'll find the most popular car specs listed here as well http://www.opieoils.co.uk/c-716-mercedes-benz-engine-oil.aspx
Cheers
Guy
Opie Oils
O
oilman
Sunny Cornwall
www.opieoils.co.uk
clk 2008
  • #2
Here are the gearoil ones
MB 235.0
Hypoid gear oils SAE 85W-90, 90
MB 235.1
Gear oils SAE 80, 80W/85W
MB 235.4
Synthetic gear oils SAE 75W/85W
MB 235.5
MB 235.6
MB 235.7
Fuel Economy hypoid gear oils
SAE 75W-85, 85W-90
MB 235.8
Hypoid gear oils SAE 75W-90
MB 235.9
Axle oils
MB 235.10
Manual gearbox oils
MB 235.11
Fuel Economy manual gearbox oils for extended change intervals
MB 235.12
Manual gearbox oils SAE 30, 40
MB 235.13
Fully-synthetic manual gearbox oils
MB 235.15
Hypoid gear oils SAE 75W-85 for rear axles with differential look
MB 235.20
Mineral axle oils, LD, SAE 80W-90
MB 235.27
Retarder oils SAE 10W, 20W, 30, 40, 50
MB 235.61
Hypoid gear oils, AMG
MB 236.1
Gear fluid (DEXRON III)
MB 236.2
Gear fluid (TASA)
MB 236.3
Steering gear fluid
MB 236.5
MB 236.6
Gear fluid (DEXRON II D)
MB 236.7
MB 236.8
Gear fluid (DEXRON II E)
MB 236.9
MB 236.10
Gear fluid NAG1 (ATF)
MB 236.11
Gear fluid (ATF)
MB 236.12
Automatic Transmission Fluid NAG2 (ATF)
MB 236.13
ATF for power distributors
MB 236.20
CVT oil for Autotronic transmissions
MB 236.81
Gear fluid (ATF)
http://www.opieoils.co.uk/c-717-mercedes-benz-gear-oil.aspx
Cheers
Guy
jimsinessex
Essex
2008 W209 CLK 320CDI Coupe
Admin
Could this thread be made sticky along with the other useful oil info?
Jim
MAAB
MB 226.9
MB 227.0
MB 227.1
MB 228.0
30,000 km.
MB 228.1
30,000 km.
MB 228.2
MB 228.3
up to 45,000 km.
MB 228.5
MB 228.51
MB 229.1
MB 229.3
MB 229.31
MB 229.5
MB 229.51
Cheers
Guy
Opie Oils
Which engine oil is the best for my car W202 193 Year 2000 C220 cdi, 160K Miles, due for B service. If I need to change gear box oil (automatic + t-tonic)
Skiday
Isle of Wight
C230
I have a C240 V6 estate on a 03 plate. Having just had an oil change with my service and been charged £93 + vat for Castrol Longtec oil I was wondering a couple of things.
Good as the provided Castrol Longtec MB229.3 might be, can it really be that much better than the recommended, fully synthetic, Selenia 20K that I buy for my Fiat Coupe 20v Turbo, which costs £6.75 net from Fiat? Surly a highly stressed turbo of a sports car (being driven enthusiastically by me) needs as good if not better oil than a big un-stressed V6? (being driven gently by my wife). The fiat specialist site Selenia as being suitable for all cars as it is so advanced. Can that be true? Could I really not use ANY other brand fully synthetic 0W-30 oil
The service book for my MB says "You can use any oil approved by MB for use in MB vehicles." - If that were true then why all the standards above?
If I did provide an alternative oil to use at the next change, would I get into trouble with the warranty (I'm with 'warranty direct' but I'm talking generally) if a claim had to be made?
As far as I can tell from the specs given above of the Castrol longtec MB229.3 spec oil they used, service intervals can be up to 30,000 klm (18,642 mls), but the service counter on the computer is counting down to the next 10,000 mls. Can I go longer between changes? Should I ask for 229.1 spec next time if it is cheaper?
Andrew
Alex M Grieve
Broom, Warwickshire
I think the straight answer to your question Andrew is yes - the lubricants would be good for a longer life than the servicing schedule allows - so I suppose the system "fails safe", and probably by quite a margin, especially on newer (2007 onwards) low mileage cars where ASSYST requires a service every year or 15,500 miles. Those who do sub 10,000 per year in such circumstances are not nearly taxing the endurance of synthetic oils.
