Mercedes c200 cdi runaway engine !
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by tonyclancs, Nov 24, 2012.
  1. tonyclancs
    tonyclancs New Member
    3
    Mar 30, 2011
    preston
    Your Mercedes:
    c200 cdi avatgarde se 2005
    I had the pleasure of my Mercedes c200 cdi 2005 engine give me a spectacular smoke show last night, i took the key out of ignition but it decided to carry on regardless until the engine stopped....What is the best and worst that could have happened here in terms of damage ? !!!!
  2. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    Sounds like your turbo bearing has given up the ghost and the engine has run on the engine oil. You could have internal damage, although usually there is none.
    Check the engine oil level and remove the pipe from the turbo to check the bearing.
    When repair work is carried out the exhaust must be removed and stood up to let the excess oil run out, the entire intake system must be cleaned, and the engine spun over with the injectors out
  3. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,825
    1,003
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    C220CDI AMG Line Premium, SLR McLaren Roadster, SL55 & C32AMG
  4. OP
    tonyclancs
    3
    Mar 30, 2011
    preston
    Your Mercedes:
    You were right guys turbo had blown,car is running ok now but engine warning light is on, borrowed a code reader and it says p1408, i believe this is the egr valve, i have cleaned it and put it back on but engine light comes straight back on after knocking it off, will a new egr valve definately cure this as this is the only code being read.
  5. carloss
    carloss Banned
    587
    Apr 28, 2009
    Your Mercedes:
    jaguar xk
    Hiya Tony
    I suggest you give this guy a call Gary on 07774 261018 Before you take anywhere he has a garage in Fleetwood
  6. nokia
    nokia Senior Member
    467
    Dec 17, 2012
    London
    Your Mercedes:
    W211 E320 CDI Avantgarde
    how do you shut an engine off in this instance?
  7. macker64
    macker64 Senior Member
    148
    Mar 11, 2012
    Ireland
    Your Mercedes:
    1997 W210 300 Td & 1991 W124 300CE 24V & 2001 W210 320CDI & W210 E200 1992 W124 300ce 24v sportline
    Discharge a car fire extinguisher (Foam) into the air intake to smother the engine!
  8. paul hayward
    paul hayward Senior Member
    1,526
    Feb 27, 2012
    Your Mercedes:
    all MB sold..V70R now ;-)
    scary stuff isnt it:shock:...crazy:shock:
Share This Page
