Mercedes C250 CDI Stage 1 Remapping!!!
Discussion in 'Tuning, Styling and Performance.' started by GAD Tuning LTD, Jun 7, 2019.
  1. Gazwould
    Gazwould Senior Member
    492
    195
    Oct 28, 2018
    Your Mercedes:
    S204 OM651
    I'm not saying they're bad remappers , but it is lying if they claim a 48 bhp increase when it actually gained 25 bhp .
    GAD don't do that , they claim the increase from stock dyno run to best modified dyno run .
  2. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    11,126
    1,660
    Mar 25, 2010
    Dartford
    Your Mercedes:
    For 3 main reasons:
    Emissions
    Fuel economy
    Political reasons (marketing, model ranges etc ) EG there maybe 3 version of the same engine in 3 trims that have 3 different power levels, all identical apart from mapping, VW TDI's are common for this.
  3. ajlsl600
    ajlsl600 Senior Member
    2,691
    863
    Nov 18, 2013
    france
    Your Mercedes:
    clk3202001,sl6002003 with everything,A class 170cdi auto
    ok. so one of the likely downsides is less mpg or the rpm at which best economy will be will likely shift ?
  4. OP
    GAD Tuning LTD
    GAD Tuning LTD Forum Supporter Authorised Forum Supporter
    1,967
    149
    Feb 8, 2013
    Essex
    Your Mercedes:
    BMW M4 - C350 CDI
    Yes I understand the reasons for posting but I don't like the idea of other tuners getting dragged into a debate
    Many thanks
  5. OP
    GAD Tuning LTD
    1,967
    149
    Feb 8, 2013
    Essex
    Your Mercedes:
    BMW M4 - C350 CDI
    I'm not saying it's not fair on us I'm saying not fair on other tuners
    Many thanks
    Wighty and V6Matty like this.
  6. dry run
    dry run Senior Member
    740
    416
    Aug 1, 2014
    Portsmouth
    Your Mercedes:
    2013 C207 E 350 CDi Coupe
    Surely if you get a reputable remap by someone who is looking at you current engine performance in "real time" and seeing if the engine mapping can be improved, you are helping the car not punishing it (regardless of power gains)?
    SmartAmg likes this.
  7. V6Matty
    V6Matty Senior Member
    5,597
    642
    Aug 1, 2012
    Newark, Notts
    Your Mercedes:
    S212/10/E350(His) W169/2005/A180 (Hers)
    True, but a map can be easily pushed with very little effort by someone not so experienced
    GAD Tuning LTD likes this.
  8. alexanderfoti
    11,126
    1,660
    Mar 25, 2010
    Dartford
    Your Mercedes:
    On a side note, as you know, a chassis dyno is used for before and after gains and is not able to provide a 100 accurate representation of engine power. They should only be used as such.
    We also don't know the situation with the graph posted, if the car had a dpf and cat removed or if it was a manual with no torque limiters etc!
    Regardless, we work with road rage performance frequently and they are good guys over there. We use their dyno quite a bit and its WHP figures are pretty accurate.
    I don't feel as though we are negatively reflecting the numbers or work the other tuner has posted on their site, just providing it as an alternative set of numbers.
    GAD Tuning LTD and V6Matty like this.
  9. alexanderfoti
    11,126
    1,660
    Mar 25, 2010
    Dartford
    Your Mercedes:
    Well, yes and no.
    Primarily its emissions, to meet emissions (Mainly NoX output and particulates) the injection timing has to be set to an ideal level. This injection timing is a compromise. By advancing the timing you get more power but A LOT more NoX production, so manufacturers have to abide by this.
    That, along with other things like rail pressures etc, dictate the efficiency, so by mapping, we can increase efficiency and increase power, therefore reducing fuel consumption, at the same or higher power levels.
    As the manufactures must meet emissions targets, and also must have the vehicles run in +50 and -40 temperatures, the mapping etc must be setup to accommodate the wide array of environmental factors, fuel quality, poor maintenance etc.
    Wighty likes this.
  10. ajlsl600
    2,691
    863
    Nov 18, 2013
    france
    Your Mercedes:
    starting to get you, does that imply that one needs to dump the dpf and nox kit to get full benefit of a remap ? as more nox is surely going to trouble both? and does a remap involve changing rail pressures..
  11. OP
    GAD Tuning LTD
    1,967
    149
    Feb 8, 2013
    Essex
    Your Mercedes:
    BMW M4 - C350 CDI
    Not always on modern DPF materials are very efficient as far as gas flow. Increases in rail pressure is what will ultimately increase nox output
    Many thanks
  12. ajlsl600
    2,691
    863
    Nov 18, 2013
    france
    Your Mercedes:
    when you refer to modern dpf ,from what yr would that be..?
  13. OP
    GAD Tuning LTD
    1,967
    149
    Feb 8, 2013
    Essex
    Your Mercedes:
    BMW M4 - C350 CDI
    Hard to say really depends on lots of models etc.... But early ones if we took 2007 as an example and compare them to 2014+ maybe.
    Have seen newer vehicles even with DPF removed not make any noticeable difference to power the limiting factor has always been something else, injectors for instance rather than DPF restricting gas flow.
    Many thanks
  14. ajlsl600
    2,691
    863
    Nov 18, 2013
    france
    Your Mercedes:
    cheers understanding better
  15. OP
    GAD Tuning LTD
    1,967
    149
    Feb 8, 2013
    Essex
    Your Mercedes:
    BMW M4 - C350 CDI
    No problem at all
    Many thanks
Share This Page
