Mercedes Comand Aps NGT2 Reversing camera
GeoMerc
Registered
Mercedes viano 2011 3.0cdi
I have a factory comand aps NGT2 reversing camera fitted to my Mercedes Viano, unfortunately the camera was water damaged.
My question is can I fit a aftermarket reversing camera to my existed cables?
I understand if the NGT2 system did not have a reversing camera programmed in then star is needed to programme it, but in my case it is already there, therefore will it be just plug and play?
Botus
S500/2010/500
NTSC camera and it should work if you wire it right …. the nasty cheap ones use RCA phono plugs, where yours will have a small proprietary merc 4 pin multiplug…. please don't be an animal and ruin the camera or worse destroy the car cutting off plugs... build something disposable to convert between the two
