Hi all,
I am new here and this is my first post in this forum after trying to find any info on the internet about om651 engines having a coolant leak problem but nothing matches my one.
I own 62 reg prefacelift E200 CDI (om651.925 variant engine) and had to add some coolant in the past, maybe couple of times over a year and a half and very small quantities so I thought it's fine abd may be the cause of evaporation. Recently, which was two days ago, add coolant message came on, so I opened the bonnet and saw that coolant is quite low level (less than a quarter of expansion vessel) so I added to normal again, that's really strange I thought but maybe it evaporated a lot driving in such hot weather over past few weeks here in UK. Biggest surprise was yesterday when I started my car after work and got same 'add coolant' message again, hence I only covered 35 miles in early morning, the level was at bottom of vessel again, topped up. After driving less than ten miles same message, stopped at nearest petrol station, topped up and finished last coolant I had in my boot. Drove off and a after few miles same, stopped again, checked, there's still some coolant left on bottom, barely made back home... While driving engine coolant temperature didn't go above (on the dash) even getting through bit of traffic. Put car into garage to see if I can find any leaks, engine off, first checked around pump and hoses, radiator, seems all fine, when suddenly noticed unusual sound coming from inlet manifold area. Here it is, leak is located, lots of liquid above intake manifold and spilled around it and down the side of engine, puddle under car too. Can't see precisely where coolant is coming from, view is very limited by loom harness and hoses, but definitely above air inlet in between thermostat and fuel filter. Would anyone have a auggestion what may have failed in there? Seem just bellow the glow plugs level... Can it be a head gasket?
Also noticed steam coming from oil filler hole while engine is hot when switched off and cap open. Some thin layer of brown residue/sludge on overhead crankshaft couth my attention as well, knuckles themselves are clean where have contact with tappets. Is this normal to see on 105k mile engine?
Checked engine oil level and looked for anything suspicious secerse times over last few days, everything seems ok, no milky stuff, dark brown oil almost black in colour, although had car cerviced 1.5k miles ago.
Any comments on this please?
Cheers. Vic
Cheers. Vic
