Could someone please point me to the page which shows the engine side accelerator cable and linkage on an automatic 1992 230TE. I have some wear on certain parts which I would like to replace, and my nearest dealer is a good way away.
When using the Ruskie site,,if you have Firefox then you must scroll down to the text
On early cars there are 2 sections on the page, those at the top half are refference to the microfiche files, the lower half after BM will open on your srceen with all of the detail.
In the link is a simple page,just scroll down on firefox and you can see the BM
Hard to say if these are MB parts or Bosch,, the best way would be to print off the diagrams and go to your MB dealer and ask them to look on the EPC, the chances are that you can buy the complete assembly
Try that first, otherwise is there any way that you could fit or replace any springs to take up the wear /slack
What is happening is that there is no way to regulate the sensor plate, therefore under certain conditions it completly shuts and stops the engine. The adjustment screws work fine, but if there is no rigidity in the parts you are adjusting you can set them properly.
Still the idle problem, but now its not and idle problem, its just an engine stops problem, but at least I know all of the sensors and the ECU are good.
Just to simplify throttles are lifted by the rod and a return springs keeps them closed, any spring should not be so strong that it would hear the pivot point but strong enough to return it to where it came from, a round type hair spring is the best as it does not cause any wear to take place, but they are the hardest to fit
