Greetings, hope I can get an answer to this question regarding a Mercedes ML270 engine. The other day the car was being driven and whilst overtaking lost all power with the engine fully dead. I was not in the car at the time, but the driver reported that there was no loud banging or other loud sounds, simply an engine struggling sound for a moment and then totally dead.
We've had the car towed to a garage and they've reported that they tested is and didn't get any compression from the engine. They are suggesting that the issue is a broken crank shaft. However with no loud sounds reported and the rarity (I presume) of crank shafts breaking I'm wondering if there is anything else that might have happened which would be more affordable to repair and which would make it worth having the car inspected by another mechanic.
I've had some thoughts that it could be the timing chain being stretched/bent/damaged, but I wonder if there are any other issues (or common issues) that might cause a similar result and might give a false impression of the crankshaft being broken.
