Vehicle Mercedes SLK 3.5 350 7G-Tronic 2005 AMG alloys Exceptional Example must be seen
Discussion in 'Mercedes Car Classifieds' started by james1345, Sep 15, 2020.
  1. james1345
    james1345 Member
    11
    Aug 28, 2020
    Your Mercedes:
    slk350 2005
    Beautifal Black Mercedes SLK350 with only 91000 miles on the clock backed up with full service history ,has a new MOT with no advisories ,has new springs all round...the best thing about this car but not the least is the 3.5 v6 uprated evo engine that puts out 272 Bhp 35 more than standard ..and will get you to 60mph in 5.5 seconds..where can you get that kind of performance for under 5k?
    Ths SLK also benefits from 18inch AMG alloys with great tyres..and a Immaculate black leather interior ..this is a truly exceptional looking and driving slk with blistering performance and a fantastic exhaust note from the the v6 and twin exhausts ..exceptional beautiful car and with near classic car status is this one for the shrewd investor....
  2. Blobcat
    Blobcat Moderator
    23,822
    9,864
    Near Grange Moor (not Wakefield...)
    Your Mercedes:
    R171 SLK280 3.0, Land Rover 110 County SW
    What year is it?
    How much is it?
    Is the engine in the “at risk” category for balance shaft issues?
    No airscarf :(
  3. OP
    james1345
    james1345 Member
    11
    Aug 28, 2020
    Your Mercedes:
    slk350 2005
    its 2005
    price 4950
    ive no idea about balance shaft issues i just drive it ..fill me in..no air scarf ,I've got a nice gucci scarf for the buyer to keep :)
  4. Blobcat
    Blobcat Moderator
    23,822
    9,864
    Your Mercedes:
    With your engine number you can check for balance shaft issues - Here
  5. 00slk
    00slk Senior Member
    4,146
    2,566
    Dec 1, 2012
    Cambridgeshire UK
    Your Mercedes:
    2002 SL55 AMG, 2005 SL500 2009 SLK350
    Looks like it hasn't any options or very few?
  6. Larkone
    Larkone Senior Member
    388
    224
    Aug 19, 2016
    NW Essex
    Your Mercedes:
    CLS 320CDI 2008
    Friend may be interested, could you post your VIN as need to check on the balance shaft issue
  7. OP
    james1345
    james1345 Member
    11
    Aug 28, 2020
    Your Mercedes:
    slk350 2005
    ENGINE NUMBER IS 27296330167850 LET ME KNOW WHAT YOU FIND THANKS
  8. Blobcat
    Blobcat Moderator
    23,822
    9,864
    Your Mercedes:
    Mercedes-Benz with the improved parts have engine serial numbers that are higher than:
    • M272 Engine Serial No. 2729..30 468993
    Yours is 30167850 :(
    Step 2
    If your engine serial number is lower than the serial numbers shown above you should perform a scan of your engine ECU, which is very easy. You will need an OBD-II scanner. Any of these Best Selling OBD-II Scanners and Code Readers on Amazon would work. Plug the scanner in the OBD-II port under the dashboard and read the fault codes from the engine ECU. You will get error codes if your check engine light is ON. If your check engine light is off, you could get pending fault codes meaning that the car is just detecting the problems but has not yet turned ON the check engine/service engine light.
    Hopefully, you don’t have any of these codes:
    Fault Code: P1200 or P1208 Pending or Stored
    Fault codes 0059, 0060, 0063, 0064, 0271, 0272, 0275, and 0276. These fault codes could be recorded as current in the ECU fault memory. If current or pending these codes are caused by a malfunctioning camshaft adjustment solenoid. If you have these codes you should check for oil leak at camshaft adjustment solenoids.
    Step 3
    If your engine serial number is part of the affected cars, then you may want to inspect further. Perform a visual inspection for wear of the teeth on the sprocket on the M272 or the guide idler gear of the timing chain for the M273 by removing the timing case cover of the engine. If you conclude that you have balance shaft engine issues, the repair is very labor intensive, and the engine will have to be removed.
  9. OP
    james1345
    james1345 Member
    11
    Aug 28, 2020
    Your Mercedes:
    slk350 2005
    Oh well all doom and gloom aside:eek: ..the car was at welwyn merx last week and was scanned with no faults present and it drives perfect ,im assuming not every single engine built within the wrong serial range numbers has broken but i really appreciate being informed thankyou and if its the case that the engine is a liability i will consider giving the car away or scrapping it.:)
  10. Blobcat
    Blobcat Moderator
    23,822
    9,864
    Your Mercedes:
    It’s just one of the things to be aware of with M272 engines unfortunately (I have one)
    They’re great engines and sound great when running as they should.
    Good luck with your sale
  11. OP
    james1345
    james1345 Member
    11
    Aug 28, 2020
    Your Mercedes:
    slk350 2005
    thanks im sure ill have them queuing up ...
Share This Page
