Mercedes Vito 639 no reserve travel
Andrew Roberts
Vito 2004 2.2
Hello I failed mot with a lot of things,
One job I have isNo reserve travel on brake pedal
So I have bought four brake callipers (used)
But better than original
Now the help advise I am looking for is the correct way of bleeding
Regardsandy
robin.large
CLS C63 AMG 2013
Best is to buy a positive pressure pump, fill with lots of fluid, screws onto reservoir. Pump up to pressure then release bleed nipple on furthest back caliper until clean fluid comes out. Then repeat with all calipers. Just keep pressure pumped up.
Sent from my ONEPLUS A5010 using Tapatalk
M80
Derbyshire
A pressure bleeder is useful.
Start nearest to reservoir 1st and work each till furthest.
I have had issue bleeding the rears through the valve previously but got there in the end.
I also prefer to go back round maybe a week later, after useage, to expel any air that's found its way toward the nipple.
A
Andrew Roberts
Vito 2004 2.2
Ok good thanks.
I have had trouble with bleeding this,before.
But will do that
A
Andrew Roberts
Vito 2004 2.2
Thank you for the advise about my Vito,
Final bleed tomorrow,
But did it today very quickly,now have firmness in the brakes,lovely.
The bolt holding the ball joint in the steering knuckle thread has run out,
Can anyone give the correct name for thisor where I could obtain one from thanksandy
www.ckinsurance.co.uk
