bulldogbrit
New Registration
- Mar 24, 2009
Just had a customer with this same fault.
Code reader said low vac pressure.
Checked vacumn pipes from brake servo and eventually found a kink in vac pipe in wiring loom by the ecu on passengers side. Pipe is black and approx 3mm diameter and is wrapped up with black loom tape and about 40 wires around it. This pipe leads too one of the vac valves on each side of the inner wings
