Mgf 1.8 vvc good or bad
Discussion in 'Motoring Related Discussion' started by Stulc, Apr 29, 2019.
  1. LostKiwi
    LostKiwi Senior Member
    18,393
    8,543
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    We have a troublemaker guys! ;)
    Racersedge and Blobcat like this.
  2. John Laidlaw
    John Laidlaw Senior Member
    20,114
    5,466
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Don’t you start me......
    E220 CDI.. AMG badge
    Tip of the iceberg :p
  3. John Laidlaw
    20,114
    5,466
    Nov 15, 2013
    Wirral
    Your Mercedes:
    Absolutely yes! Brand new too :)
  4. John Laidlaw
    20,114
    5,466
    Nov 15, 2013
    Wirral
    Your Mercedes:
    His Mercedes is an A4:rolleyes:
    Blobcat likes this.
  5. DREAMER NO2
    DREAMER NO2 Senior Member
    2,647
    326
    Dec 29, 2013
    Your Mercedes:
    W124 2.6E M103 1989
    stulc if you need a pair window regulators i have spares in my garage ,
  6. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Might go for a 99/00 1.8 auto don't think it's the vvc/t though
  7. 400ixl
    400ixl Senior Member
    372
    134
    Feb 21, 2016
    Your Mercedes:
    E250 AMG Sport Convertible
    That will be the MG F 1.8 i then as the VVC never had the auto CVT box. If it is a post August 99 car then it should be the MY00 model which was often referred to as the MkII, and is when they steptronic (with the CVT auto gearbox) was released.
  8. OP
    Stulc
    Stulc Senior Member
    405
    7
    Nov 8, 2003
    In the hills
    Your Mercedes:
    W203 C180k
    Yes that's it
    Needs the h/g done though and the 2 mechanics I know won't do it :mad: so I need to either try and do it myself or get it to somebody I've never used.
    Very good condition though and only 48000 for 19 years old. I'm wary of the auto though even though it's only nearly 50000.
  9. 400ixl
    372
    134
    Feb 21, 2016
    Your Mercedes:
    As per my previous post. Make sure you get the latest Head Gasket Kit, also change the ladder rail with the strengthened one. I would also replace the stretch bolts at this age, even if they are in tolerance.
    Head should only be skimmed if out of tolerance as you don't want to remove the hardened surface if you don't have too.
    I would also be fitting one of the aftermarket coolant warning kits as well whilst you are at it.
Share This Page
