mirror indicaor lens
allmerc
West Sussex
2004 CLK270CDI
Hi guys
Once again I come here for help. Does anyone know how to change the indicator lens on a side mirror on a 2001 C-180? I tried but it looks cmplicated.
I can send you the papers. its easier to do that.
That will be a 203 I think.
allmerc
allmerc
West Sussex
2004 CLK270CDI
Hi Molcolm
By the way, your advice on the rear lights worked, replaced both bulbs and the warning disappeared. many thanks.
Many thanks in advance
EJ
allmerc
allmerc
West Sussex
2004 CLK270CDI
yes, I forgot, it is a 203, thanks
I have emailed it to you,, you can go back to your last post and in edit remove your address :D
SLKBOYO
I have a similar problem on my 2000 slk200. Someone has knocked the lens causing it to slide into the housing leaving a gap of about 10mm. I have tried, with force to slide it back into position, but it will not budge, looks as if I will have to take the mirror out to gain access. Is it a simple enough job ? and how, any advice much appreciated
Though it easy to describe I have sent you a paper for both,its quicker:D:D
SLKBOYO
Thanks for the quick response Malcom i'll give it a go tomorrow
