misfire on no.1 cyl c200komp 2003
podmo
newcastle
2003 c200 komp,2002 audi a4 2.5tdi
hi all having just re done the head on my c200 komp it not running all that well, the chap across the road stuck a code reader on it and it came up with misfire on no.1 cylinder, now there are 4 brand new coil packs on the car and i was wondering if anybody has any ideas as to what i could check to remedy this? im wondering if with me taking the head off which included taking many hoses,fuel rail,sensors ect i may have disturbed something? its the 271 engine, many thanks :)
rpe2
Silchester
Do a search for sticky valves = or was this what the head was off for?.
Why not change the coil pack over to another place and try it
P
podmo
newcastle
yes richard,i took the head of to replace all the inlet valves
P
podmo
newcastle
yes malcom il try that tommorow, maybe its just a faulty one from new or a spark plug is faulty
busby20
Glasgow
SLK's 2, CLK320 Cabriolet.
Had a similar problem a while ago with my old C180, specialist couldn't find the fault, however, another garage used the older "Sun" type oscilliscope type and discovered it was one of the "new" coil packs that I had fitted previously, it was malfunctioning and causing an intermittent misfire. Suppose the moral is, just because it's new doesn't mean it aint faulty!
P
podmo
newcastle
yes il swap them about and see what comes up,im kind of hoping it is a faulty one just to make things easy for a change,the car is of road at the moment so cant take it to get put on diagnostic jobby, im thinking of checking coils,plugs,fuel injectors/leads as there the parts i have had off, after that im in no mans land ,not got an igloo what to look at after that
busby20
Glasgow
Go back to basics, i.e. Fuel+Air+Compression+Timing+Ignition = Power. Sounds simplistic, but if you think about it logically and check the various steps of this sequence there must be a break in the chain - so, if spark is o.k. check fuel, if fuel is o,k. check air, etc.etc. got to be there somewhere ;);)
P
podmo
newcastle
i will do busby,ive just swaped the plug and coil to no. 2 cyl and will see if its swapped the misfire to that one,just waiting for a code reader of the chap over the road,im sure as i go through the list i will come across the cause,
yes blackc55 il do a compression test today,ive done the valves so maybe there is a fault with one
P
podmo
newcastle
just an update, changed two coil packs round and it still sounded like it was missing, however,went to start it again 30 mins later and it has cured itself,dont know how but im not complaining, maybe it was a loose conection,
thanks for all your input gents
sorry podmo. the missing is due to the ecu shutting down one or more cylinders. it will do this at the drop of a hat, because it detects cylinder misfires over a certain threshold that you may not even notice! often 'turning it off and on again' will reset it for a while. did you grind the valves in?
P
podmo
newcastle
sorry,have been away on a jolly, yes i ground all the valves in so they were well seated,had a good test drive in it and withought problem,its running very smooth now,i will have to keep an i on it and see if it happens again
could be the split hose you may have read about - do you have a code scanner?
P
podmo
newcastle
had a code scanner which the chap over the road plugged in,just came up with missing on no.1, still seems fine now, il just have to wait and see if it happens again,which im sure it will but you never know
newusermb
Hi there,
I got the same problem as Podmo. But my car is C200 Compresor 2002 -engine 111. Is it because of the coil injector?
