Isdyldan
- Dec 9, 2008
- Location
- Woking, UK
- '71 350 SL, Mercedes 350 CLS SB, '94 Shogun 2.8 LWB, '73 Porsche 914
Hi - could someone help me cure my running problem please? I have an '81 380SL which I acquired as a non runner. I messed around with the timing but eventually found it had the wrong coil on it. I bought a standard looking second hand blue coil from Mercman and it started up fine. After starting & stopping a number of times to get in & out of the garage to work on it, she is now only running on about half the cylinders, and when I remove the plugs they are wet with fuel. The car has ballast resitstors on it - could it be that I still have the wrong coil please, or does this sound like the timing maybe? I have no idea how to statically time this engine as I couldn't get a voltage to drop across the coil as I twisted the dirtributer - is there a technique to static time this engine please? last week it ran fine again for 10 minutes or so but is now lumpy again! Any ideas would be more than welcome.
