Hi everyone!.My 86' 190e 2.0 ltr. has developed an annoying missfire at the weekend.You can feel the missfire in low revs as you pull away and also the tickover has become lumpy.Pulled the plugs and found No1. plug to be sooty.Put new plugs in...no differance.Substitude No.1 lead ....no differance.Replaced rotor arm and distributor cap....no differance .Checked out the votage at diagnos socket, resistance at switch unit and the resistance on the coil...as per Haynes manual.....all ok! Took the car for a spin...3 other plugs are a nice colour, No.1 still sooty!.
Will perform a cylinder leak-down test next , after making a tester.
Does anyone know if there is something else in the ignition system that I need to address that might be causing this problem that only seems to be affecting No1 cylinder ?Your help would be much appreciated !
Many thanks Ron H.
Many thanks Ron H.
