Kodyeml270cdi03
- Jan 14, 2021
- Ml 270 cdi 2003
After a long week working on the car after flooding it in a massive puddle once I got out the puddle I had no gears only N and P I could rev fine just no acceleration power when put in to gear I’ve managed to fix most codes apart from some ,I have dried out the car and blew our most plugs with air
Changed starter motor
Changed engine oil , oil filter
changed trans fluid (3.5l)as was full of water changed trans filter I am now
Thinking I need to the flush the entire system as torque converter will be full of water also ?
issue I’m having is can’t get the car out of park with out doing emergency release then when I do it’s got not transmission/ very little to no acceleration
Main problem code I’m
Getting is p1925
Any ideas ?
Getting is p1925
Any ideas ?
