ML 270 CDI auto, idler pulley broke
Garista
France
2001 ML 270 CDI. 1991 R129 300 SL
Hello.
So I installed a new water cooled alternator, all went fine, took ages to get the part though and the job was not exactly easy peasy. Worked great no problems.
Then the other day on a trip the idler pulley (which is plastic) completely broke, and left the belt running on the central hub bit, which smoked!!
So I am going to have to change it. Probably I should have serviced this part and the belt at the same time as the new alternator. Now I know they do a kit that includes the idler, the belt and the tensioner pulley. You live and learn.
If you have any tips let me know, otherwise maybe this will help someone.
Idler is a non serviceable item - better off just replacing it - mine did similar - I'd recommend changing the tensioner at the same time as that will probably be on the way out as well..
(I did the idler on mine as the bearing gave out - the tensioner went a week or so later...)
Give Mercedes Grangemouth a call - they give forum discount
Thread I did when I changed mine on my M272 engine
rifiki
Worksop
CLK W209 W121190B
You are lucky, had similar problem. The tension pulley seized and the shredded belt wrapped it's self the crank shaft between pulley and engine block causing more problems.
G
Garista
France
Ouch! Yes we were lucky, but quite used to being very sensitive to the noises and smells after doing any work.
I think I should really buy the whole kit, but I will do the idler pulley first and get the other parts separately, as I want to make sure it is febi bilstein one.
G
Garista
France
Is the tensioner pulley also plastic?
Sounds like a good idea to do it all at the same time. So I won't of course.
It is, please take a look at the thread I posted
rifiki
Worksop
CLK W209 W121190B
Change the lot and only use branded ones, SKF, Febi etc.
G
Garista
France
I put on a febi-Bilstein idler. Searching for the other two at the moment. On a budget but will get quality.
G
Garista
France
Was quite easy to put on, not much access but it is high up, I found I could loosen the fittings for the radiator and pull it back a bit out the way. You need a short torx bit in a ratcheting spanner ideally.
The belt looks quite good but I will change it soon, and the tensioner. Saving up :).
