ml 270 cdi heater
cobra
staffs
Hi Guys another newbie.
just purchased o4 ml 270 cdi, with two problems
1 heater will only blow cold but aircon appears to work also heat distribution only blows into footwell no matter where the knob is set (no heat at any time) both in and out pipes to heater feel hot and consistent with eng temp
2 rear wiper not working, sounds like motor moving, is there any linkage between motor and arm as wiper feels tight on spindle
any thoughts or ideas would be much appreciated
cobra
C
cobra
staffs
  • #2
heater
have i done something wrong ?
posted in the wrong section or something, if i have apologies could somebody
tell me where to post,
if not any help or ideas would really help, as i am at a loss as to where to start
cobra
kebo57
Lanc's
ml270
Hi and welcome
I have searched and only found this
quote Not sure on the heater circuit but you can get it plugged into a diagnostic computer at your local dealer or indie as the EAM/AAM controls the heating circuit and it will report the fault code (hopefully).
Cant be more help, hopefully someone else will have experience of heating circuits.
You could check the fuses I think that you heater should blow hot as soon as you start the engine due to an electrical pre heat system
Same with wiper, switch in on position fuse in & out to see if motor will run
This might help http://www.detali.ru/cat/oem_mb.asp
Please post a reply Kevin
C
cobra
staffs
270 heater
many thanks kebo57
will have to find a local indie to get the codes read will post the results as they might help others
cobra
