Hi,I've just bought a w reg ml 270 which was cheap due to number one injector leaking compression.I'd heard this is common and as it's the most accessible thought i'd tackle it.The whole of the top of the engine was covered in some black sealant which wasn't doing a lot apart from making my job harder.After removing the gunk i easily pulled out the injector and ordered new bolt,washer and clamp and cleaned injector on wire wheel.today i thought i'd run a tap through the bolt thread only to find no thread!!!I'm now faced with a problem.i tried to drill out clamp to 8mm but it's seriously hardened so do i chemical metal a 6mm stud in or tap the chemical metal for original bolt.Got to be worth a try before i take off head.Cheers in advance,Paul
