ML 270 cdi stuck in park
Duncan.ml
ML 270 cdi X reg
Hi there,
I have a 2000 Mercedes ML270 cdi, but it has just started getting stuck in park. I'm currently curing the problem by sticking a biro down the hole at the bottom of the selector to get it out of park. However, I would prefer a more permanent solution.
Any ideas anyone??
The brake light switch is a possible cause
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Didn't Helen have a similar problem? Can't recall what the gizmo was called, but it was an electro-mechanical switchy thingy. Sorry for the technical terms :rolleyes:
There are a few things for this Jez, from the steering lock cable, the gear shift ecu and the ignition switch,,I am looking around on this
angry
Newcastle upon Tyne ,england
Brabus ml w164, cls 350 CDI w219
h there just had the same problem with my 2002 ml replaced brake light switch above pedal 11 quid from local mb stealer easy job (even i could do it) quoted nearly 120.00 from local stealer
A lot of money can be saved on many jobs, just by having a go, £120 not bad is it, thats more than I used to earn per hour :rolleyes:
