ML 270 CDi
luders79
London
W210 estate
Ive got one that intermittently starts, but must of the time It wont even crank over! when it wont start you can tell its going to happen as the suction fan runs on full speed. when it doesnt start no comms with engine ecu and can fault codes in other modules saying no comms with engine! Could it be a power supply probelms to the ecu? would the fan run at full speed if engine ecu is not fully powered up?? If not why would the fan run!
Thanks for any info
Lee
Uncle Benz
West Sussex
Mainly Mercedes
Fan command is via CAN, sourced from engine ecu (IIRC...) so it suggests that something is going on with the engine ecu. Worth having a look at the ecu wiring, particularly the earth. Sadly you can't try one from another vehicle, and ecu testing companies can be a bit variable...- but you know that already...
Fan controllers do fail commonly. Might be worth unplugging the small CAN connector from the fan controller and see if it makes any difference, but I think that it's a long shot.
wel matey, with das we can easily pinpoint the problem with drive authorisation signal test. how do you know the comms faulty? has it been on a diagnostic, if so which one? also does it say `start error` in dash?
this is probably colin's sort of thing, i think he has particular expertise in breakdowns. i do know that they occasionaly have failing AAMs (module/fuse box in engine bay) this could well explain the problem, ecu is easy to check for power supply. also have a seperate D.A.S module which deals with the transponder and cans to AAM then CDI (from memory), these also can fail but do not really fit your symptoms.
so my guess, failed AAM (all activity module). later models also have an EAM (extended activity module) but i don't think this is in the chain.
Does "Start error" come up in the dash
