ML 270 injector leeking seal
kebo57
Lanc's
ml270
Hi to everyone
I haven't posted for a while,
I have a problem with an injector seal leaking see picture
What would be correct procedure to replace the seal & re-seat the injector and any other information that might be relevant
Thanks in advance
Kevin
kebo57
kebo57
Lanc's
ml270
I have a tool to re-cut the seat.
Give me a call.
Great & thanks for the reply but you 300 miles away
When you use the tool are you actually removing metal
our just polishing / cleaning
I will call
Kevin
kebo57
kebo57
Lanc's
ml270
Give me a call.
Hi this guy Say's "Ask me anything! 02392 570 123"
So I did and once again he put me right, he is a top man,
So thank's for your time black c55
May be I could help you out one day
I have turning & milling work shop if you need anything
Kevin
exeng
if you need to recut seat i also have a tool that does both the head and injector and i am up north if i can be of help send e mail
kebo57
kebo57
Lanc's
ml270
Hi It's me again would anyone know the voltage that goes down to the injector so I can reproduce it and test an injector would I be able to here some sort of clicking also there are two terminal in the connector at the top would they be live and neutral
Kevin
kebo57
kebo57
Lanc's
ml270
Hi this is the conclusion to the thread
I had three injectors leaking two of which came out easily
The third No one nearest rad was stuck / seized in
So I had to make an extraction tool with 3 Kgs slide hammer see pic's
Then I needed to clean the location bore for the injector
So I made a 3 diameter reamer see pic's
Then I needed to re-cut the seat in the cylinder head so using the reamer as a guide bush made a spot facing tool to re-cut the seat see pic's
Then I needed to re-machine the injector mating face so I back turned it in my lathe and polished the diameter to aid the extraction next time no pic's for this one
Re- assembled with new copper seal, new bolt, and copper slip along the full length of the injector it went back a treat
Then set of for Kent 600 mile round trip with no problems better MPG more power more acceleration
This job set me back £2.73:D:D:D:cool:
Kevin
panason1c
Somerset, UK
:) Nice job Kevin......;) Thanks for the useful update.
wireman
lancashire
What a nice looking reamer
lphot
leaky injector
I know this is a dumb question but how do get the small pipe off the top of the injector it has a clip, but after you take it off the rest doesn't budge?
Is the best away to get them out still lossen them and drive down the road a bit?
Cheers
rpe2
Silchester
Take the clip out and the pipe will pull out.
Xiper-V
Shepton Mallet
ML270/2001/2.7
Hi there,
I have this issue with my 4th injector (some modifications - had to be made with the bolt last time)
I recut the seats on my ml270 please can anyone advice if this is a good enough cut (please see picture attached - noticed there is some tiny bits of crud that needs to be removed after photo has been taken)
but when I put her back together it spits ever so slightly out the left hand side of the injector (bolt facing at the front when looking at the injector)
Admittedly I have used the old clamp (I have purchased a new modified one and its on it way in case this is the problem)
Is there anyway or tool I can use in order to check the seat is cut at the correct angle the injector sits? or if the seat is level enough (looks perfect to me when viewing it at the top)
Cheers guys
Xiper-V
Shepton Mallet
ML270/2001/2.7
PLS PLS HELP!!!
Please please help before I smash this f**king car to bits!
(I have spent loads of money on her and a lot of my time sortings loads of the common problems especially the inlet manifold -delete)
Just got the nack of doing the injector seals (started to clean everything up so I can take all of my injector out until I discovered this little whole by the clamp)
Do I stop now? smash it to bits? scrap it? or would it be ok still?
(Thirdly do I have to by a rocker cover?)
If I do need to by a rocker cover do you have to take the injectors out to remove this or what needs removing?
(please find attached picture)
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
If you have made a hole in the rocker cover then yes you will have to replace it.
1. Remove injectors
2. Remove rocker cover
3. Ensure all the injector bores are clean and seats as you want them
4. Replace rocker cover but do not tighten it fully
5. As you have cut the seats, use a thicker washer (on ebay)
6. Use MB 'special grease' or similar on the injectors and install them
7. Tighten rocker cover to correct torque
A new rocker cover gasket is advisable
Xiper-V
Shepton Mallet
ML270/2001/2.7
Thank you bob
Almost removed my rocker cover just got a majorly stubborn 5th injector doesn't help there's no room with the slide hammer.
Once that's out hopefully the rocker cover will come off
Thank you for your advice
