ML 270 Rear disc, Parking brake shoe’s replace
kebo57
Lanc's
ml270
I have a how to for the above but I want to post it with writing above each picture in turn how do I go about doing this also I want pictures not thumb nails
Kevin
To post large pictures,the ones that you want to use must be uploaded to a host site like "photobucket" these are free to use sites. When you have done that if you hover your mouse over the picture that you want to upload and some links will open below that picture, and you use the "direct link" copy that and open the little square box above in the reply box to the threads here, with the 2 mountains in it, thats the 5th from the right in the top row. when that box has opened, remove the http from the box and paste in your direct link. You can now go to "edit" and your picture should be there.
Please write it all out and post it with the pics and let us have a read,,this must be a new post and not on the end of this.
If all is fine I can ask anyweb to send it to the DIY
kebo57
kebo57
Lanc's
ml270
Thanks malc for this
I have done it in word so I need to do the above, if I went with the thumb nail standard option I just get a row of pictures can I have writing then pic then writing then pic and so on
Thanks Kevin
Thanks Kevin
I have not tried that but you could post it,then go back to edit and see if you can sort them,,if it does not work,,then go to delete and remove it all.
The other way is to give the picture numbers and refer to them.
kebo57
kebo57
Lanc's
ml270
Ok i'll see what I can do
thanks Kevin
