ML 270 Slow starter
Back to this problem again.
270 CDi takes a lot of cranking to fire.
It tried to fire ish but takes a lot of cranking.
I have what i would call almost no fuel coming from the inj bleeds.
Slight air in the pipes, but again minute bubbles only now. (After my high tech fuel filer replacement with a 1.8 Ford unit)
Could it be glow plugs? MAF? Weak starter?
It has a recon pressure pump and injectors already.
I hate my Merc.
I also have a broken locking wheel nut key. MB parts said that their workshop has a set of keys? Anyone know about this?
HELP!:confused:
rpe2
Silchester
Ask any decent tyre fitting firm for help with the wheel key.
Re the starting, most likely to be air in the fuel lines. Cure: new pipe seals. The seals cost pence, fitting is quite fiddly.
