ML 270 window
kebo57
Lanc's
ml270
Hi all
The button that operates the drivers window is starting to fail I have to pull with a lot of force to get the window to shut and now it is on a wing & a prayer so I'm not using it.
The switch is in a block of about 6 switches, could I dismantle & repair it our do I need to replace the whole thing
Thanks in advance Kevin :(:(:(
Hi Kevin, I would try a good switch cleaner, not WD40.
If you can get to the contact, maybe you could adjust them
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Hi all
If you require the block of switches to be replaced, expect to pay around £300 at a MB Dealership.
Not sure about repairing it - if one switch has gone, the others might not be too far behind :cry:
kebo57
kebo57
Lanc's
ml270
Thanks Malcolm
I need to figure out how to get the switches out
a new switch is about £85.00
Kevin
Thanks Malcom
Kevin
If you get stuck, just ask and I will look it up
kebo57
kebo57
Lanc's
ml270
Malcolm great to see your still banging away at these threads
I see you almost up 20,000 posts
Ever thing is very much appreciated
Kevin
panason1c
Somerset, UK
Hi all
Hi Kevin,
Check out this linkfor a method of repairing your door switches....
http://www.grill.org/rodney/mclass/mlswitch/index.html
kebo57
kebo57
Lanc's
ml270
