ML 270cdi won't start!
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by yorkinmadoc, Nov 30, 2012.
  1. yorkinmadoc
    yorkinmadoc New Member
    9
    May 23, 2012
    France
    Your Mercedes:
    ML 2002 270CDI
    Hi, strange problem, my ML is difficult to start when pointing uphill. The problem seems to be that the fuel is not getting through when on a slope. it starts perfectly when on the level or pointing downhill.
    Any help will be gratefully received, however prefer DIY solution as nearest dealer is 60 miles away!
    Yorkinmadoc
  2. WG M-B
    WG M-B Senior Member Authorised Forum Supporter
    3,105
    6
    Dec 5, 2010
    North west london
    Your Mercedes:
    C63 Wagon in black
    Air is getting into the fuel lines. You can buy a set of fuel lines from mb
  3. bigtwin
    bigtwin Banned
    964
    Apr 19, 2006
    I had exactly this problem with mine.
    It was indeed air in the lines. But, there was nothing wrong with any of the system, turned out that a batch of below par diesel had partially blocked the filter, causing the engine to suck harder, causing air ingress. That air then drifted up to the block end of the gubbins when parked nose up - no startey motor till cranked a lot.
    Couple of quids on a new filter and all was back to normal, and has been since.
    Probably worth a try.
  4. OP
    yorkinmadoc
    9
    May 23, 2012
    France
    Your Mercedes:
    ML 2002 270CDI
    Thank you for the tips I will change the filter and see how it goes.
    John
Share This Page
