ML320-Stu
- Jul 3, 2009
- Location
- Essex
- 2001 ML 320 & RS 500 & Honda XLV motorbike
A month ago my wife purchased a 2001 ML320 and a problem has now cropped up with the Remote Central Locking and i need a bit of advice please.
The central locking will not work remotely via the key fob (even with new battery in the fob) and the central locking will not work if you use the key, it will only lock and unlock the drivers door, if you want to lock all the doors you have to push the button on the centre console which locks all the doors, then lock the drivers door with the key.
The dealer the car was purchased from has said he will repair the problem and has already had the car in to do it, but has said the part he ordered was not faulty, and he now thinks the key needs either replacing / or re-programming and this will make the remote central locking work again ??
Is there any truth in this that this should fix the problem or does he have the wrong information?? and if true, any idea how much it will cost as he has a limit to what he will pay to have the problem repaired.
Cheers!
Cheers!
