I have a 2001 ML270 diesel and use it to tow a caravan, I have a problem that when towing, and only when towing the gearbox will stick in gear. The triptonic stops working, I have to pull over, turn engine off, wait a few minutes then start back up and it is normally ok. This used to happen towards the end of a long journey but last time out it happened after just several miles. The van is a big twin axle about 1900kg loaded but this is well inside the manufacturers recomendation of 3500kg. I also had a recent problem of no kickdown and this was the flow sensor, so this has been renewed. The sticking gearbox has been happening before and after the replacement of the flow sensor. The car was recently serviced (not by mercedes) but by a good local garage.
Anyone got any ideas ??
