fastboysparky
Hi Guys
The latest problem with my wifes ML.
It started some months ago when the ESP/BAS light came on, restart the engine and it is fine for maybe a week or so.
Then the ABS started to kick in for no reason under normal breaking, but not all the time.
Now the pedal travel to near the floor. The brakes are progressive and sharp when eventually the pedal gets their. The pedal goes hard if you pump it.
Once pumped up, if you keep your foot on it, it slowly goes down.
If you pump it up then turn the engine off, you can press it as hard as you like and it stays rock hard.
Need to sort this problem as wife is now using my car and i have to walk.
Cheers
Cheers
