psmart
- Feb 7, 2006
Numerous discussions recently about engine mountings on 270cdi engines causing vibrations through the car. Symptoms are normally vibrations felt when the vehicle is cold, or around 2000rpm when vibrations can be felt in foot and steering wheel.
Below are photos of engine mountings from an ML270cdi, twice diagnosed by a dealership as being fault free.
If you look at the mounting, the lateral movement rubber is indeed intact, the vertical rubber has vanished, hence the vibration. Rubbing marks are evident where the upper and lower components of the mounting have been touching.
nb) On an ML270, replacing the mountings is not an easy job because of the location of the mountings. Basically, front wheels off, arch covers off, underbody panels off, water reservoir, accelerator sensor, oil cooler, oil reservoir, oil filter, charge air pipe and catalytic converter clip all need to come off and the engine lifted with an engine hoist. Some of the bolts are difficult to get to.
